Originally Posted by Jager
Do you have a Bentley manual? Page 24-2 shows location. It's attached to the side of the Throttle Body housing. Make sure your electrical connection to the throttle body is good? Did you clean the throttle body?
I did not clean the Throttle body. Is that something I should do?
I imagine its never been done before.
I have a Bently manual and see where that unit is now, thanks for the reference.
I wonder if the oil from the AOS failure has somehow fouled it.
After reading the Bently manual I read that if you reset the codes the DME does a relearning process but you have to leave the ignition on for 1minute without the car running and then turn the ignition off for 10 seconds.
After I did this the idle has now settled to a regular steady idle and does not stall when revving.
Still some oil to burn out of the intake though but I want it to run steady before I take it on the road.
I think a while longer in the driveway when its up to temperature and it might be OK.
I'll durametric it to see if there are any faults now.
"It broke because it wants to be Upgraded
