Originally Posted by markskyline
Thanks for the video! What silicone do you use when you seal the lens back?
Mark, RTV silicon in black is good to go given it is from a reputable manufacturer and rated flexible. Your local auto store should have this in stock or able to recommend a good one. I've been using 3M for all the retrofits that I've made here (over 40 headlights or similar.... stopped counting)
Ultrapro Silicone Gasket, 08700, Black, 3 oz tube - Shop3M
Dries fast, and it flex just perfectly. Makes things 100x easier in case you need to re-open the headlight for whatever reason.
