Old 04-11-2014, 12:37 PM   #13
jb92563
jb92563's Avatar
There is an option to add a UV dye which is a bit more inconvenient because you need a UV flashlight but should work just fine. ~$8
Probably worth it if your a racer and do frequent changes. You could lay a "band" of the UV fluid with the existing gold and you will see it in the drain tube for a couple seconds as it passes through, indicating you have reached the fresh fluid.
Interdynamics Oil and Fuel Systems UV Dye (1 oz.) 374CS: You
