Old 04-03-2014, 11:53 AM   #8
Jamesp
Beginner
Jamesp's Avatar
Peel up the little cover by your hand. There is a 10mm bolt under it that holds the plastic air dam down. The air dam plastic under the bolt has broken, I repaired mine by removing it and re-enforcing the plastic surface under the bolt using 5 minute epoxy and some fiberglass cloth.
2003 S manual
