Old 03-23-2014, 02:44 PM   #11
thstone
Getting ready for upcoming races at AutoClub Speedway with PCA and Willow Springs Raceway with POC so I had the car at the shop for some lightening and maintenance;
Weight removal = 84lbs Car is still about 75lbs over min weight (with driver) so there will be more to come on this subject.
  • Remove front and rear crash bumpers – 30lbs
  • Remove one low speed radiator fan - 12lbs
  • Remove passenger racing seat + mount + harnesses – 25lbs
  • Remove windshield wiper system – 8lbs
  • Installed lighter "clam shell” mounts – 5lbs
  • Removed trunk carpet & heater core coolant pipes for heater core – 4lbs
Upgrades/Maintenance
  • Install wheel studs to make tire changes at the track easier
  • Improved alignment - add more camber, still wearing outside edge of tires
  • Improved ride height - set car to min spec ride height and optimal rake
  • Nut and Bolt - torque check for all fasteners
  • Change air filter
  • Change oil + filter
  • Top up power steering fluid
  • Top up brake fluid
Next weekend - new brake pads and rotors!
