Thread: torn cv boots
Old 03-22-2014, 08:53 PM   #1
thstone
Originally Posted by oc-boxster View Post
Thanks for the information. I will make other arrangements to get around next week. My mechanic is only 6 miles away so I'll make that the only miles that go on the car in the mean time. My mechanic used the term "redone" what exactly is done along with replacing the boots? Just new grease and clamps? I'm wondering why my mechanic is sending them to someone else to do. Is there any other recommended work to do while the axles are out?
You may have to ask your mechanic exactly what "redone" means. The simplest approach is to just re-grease the existing CV joint and install a new boot. The more complicated/expensive method is to install a replacement CV joint, grease, and new boot.
