Originally Posted by The French Dude
Thanks!
And does the 4 point will fit ?
A 4 pt harness will have the same issues as a 5/6 pt harness in regards to falling off the shoulders using the stock seat. Hence, it is not recommended to use a 4 pt with the stock seat either.
With the correct seat, a 4 pt harness will work but if you're going through the cost and effort of replacing the seat, you might as well get one that has a sub belt hole so you can use a 5 pt harness. This will provide add'l safety by keeping the driver from sliding out from underneath a 4 pt harness.
