- Check all front suspension components, mounts, and bushings, including steering rack.
- Spend $45 and install GT-3 brake ducts for better front brake cooling.
- Check wheel bearings.
- Check tires for excessive wear especailly on inside portion of the tire. This is often missed when inspecting tires on the car because the wear is not easily visible.
- Check the front underbody panels to be sure that they are firmly mounted to the car and not flapping in the wind.
