Old 03-05-2014, 09:29 PM   #5
jc986
jc986's Avatar
I think what you are missing is that the magnet catch and build up ferrous debris that has a particle size is too small to be captured by the OEM filter, and which would continue to circulate around the engine if the magnets were not there, and which act as a very fine continuous abrasive. Filter magnets have been used for years in aircraft engines to remove this fine grit before it does any damage.
I understand, just figured the Porsche engineers took this into consideration when designing the engines. I don't know if the OEM filters block particles smaller than 20 microns or not (I know some filters come in 10 or 20 micron versions) but if they use them on aircraft, then maybe it's not a bad idea.
97 Boxster 2.5L
07 Mercedes C230 Sport
jc986 is offline   Reply With Quote
