Old 03-03-2014, 11:37 AM   #10
jb92563
jb92563's Avatar
Originally Posted by seningen View Post
I track my Boxster -- when it gets loose -- you give it more gas.
So far I have found it very controllable on track. I'm assuming gravel would be
the same but at slower speeds.
Mike
Giving it more gas to plant the rear only works if there is sufficient traction, which there likely will NOT be on loose gravel unless you have mudder tires installed.
Giving it gas in the gravel will spray stones and allow the rear to switch ends with the front most likely, so you can see the face of the guy following you with stones all over his hood just before you arrive at the scene of an accident....Yours!
