Thread: Overheating
Old 02-26-2014, 09:52 AM   #7
mikesz
mikesz's Avatar
I have a 99. I was able to check the fans by removing the 4 relays for the fans in the fuse block and using a JUMPER wire. Put one end of the wire in the bottom and top slots for each relay and the fans should go on. 2 are for low speed 2 for high speed. found out my right fan wasnt working at all, was binding and causing my fuse block to fry and the left fan was only working on high speed. If you search the forum there are good pics to show what needs to be done.
99 Porsche Boxster
