Old 02-25-2014, 06:31 PM   #11
993innc
993innc's Avatar
Indeed I do know, and completely forgot to look this morning too.....had a meeting that interrupted hanging out longer with the alignment guy. But he didn't mention anything about it. I caught the need to worry about it as I was installing the LCA's, and with the spacer rings that come with them (to raise or lower the outer ball pin height), I think I got it taken care of. I can check tomorrow with the car in the trailer. Thanks for the renewed heads up.
I don't have the sheet in front of me, but I was able to manage (with 13mm worth of shims and a hint of honed out upper strut holes), just shy of -3 degrees camber. -9 degrees caster and a hint of toe front. Camber in the rear was about even with the front, and a hint of toe. I'll post actual numbers tomorrow. I didn't dial back the rear camber simply because I felt with my narrower rims and slicks, I thought it best to leave the added help keep all the rubber on the road. You're welcome to chime in
Chris
- 1997 993 (started it all) - 1975 914 1.8L w/F.I. (restoring now) - 1985 "1958" 356 Speedster (cruiser until 914 is complete)- 2002 Boxster (future, ney...current! track car)
RENT ME FOR YOUR NEXT VACATION: www.vrbo.com/489534 or www.vrbo.com/499924
993innc is offline   Reply With Quote
