Old 02-23-2014, 08:07 AM   #12
thstone
The Kumho Ectsa XS, Hankook R-S3, and Nitto NT-05 are my favorite street/track tires. Great grip and affordable.
+1 for everything Lap1doug wrote.
Max out the alignment for performance/track. While that might sound extreme, the stock suspension has such a limited range of adjustment (around -1deg camber) that there is almost no benefit or reason to consider swapping the alignment back and forth.
As a novice, you are not likely to wear tires faster by "driving wrong" because you're also driving relatively slowly. The more skilled you get, the faster you'll drive and the faster you drive, the quicker you wear the tires.
Keep driving and getting better/faster and eventually you will find that you are a better driver than the stock suspension with street tires (the car is holding you back). At this point, you'll have to consider tires with more grip (r-compounds) or a suspension upgrade. But don't worry about that until you get there.
