Old 02-21-2014, 02:01 PM   #1
Jager
Jager's Avatar
Originally Posted by allukka View Post
Thanks a lot! Will check those. Was this cleaning exercise long hours?
Guys, what about faulty AOS, could it cause vacuum leak? Or oil feed to air intake affecting emissions?
T
While the motor is running, and warmed-up, remove the oil fill cap... What happens? Is the cap hard to remove? Does the motor stumble and almost die? Is there a lot of vacuum from the oil fill tube (like a shop vac) or, does the motor idle go up a few RPM's and little vacuum from the oil fill tube? Place you hand over the oil fill tube to feel for the suction, there should be very little.
Jäger
300K Mile Club
