Old 02-16-2014, 03:06 PM   #1
jsceash
jsceash's Avatar
Originally Posted by Adz_Boxster View Post
Has anybody used or know if you can use a head gasket sealant on the boxster. I have the tell tale sign of white smoke and disappearing coolant. Would a sealant be ok for a temporary fix whilst I save up for the replacement gasket or will it do a greater damage? I'm gutted as I've just replaced all of the coil overs and she was running perfect again.
Any info would be appreciated
Your not going to feel any better after this either. Check your compression do a leak down test or have your local mechanic and expect the worst.
MY history is
