Old 02-16-2014, 08:27 AM   #11
thstone
Wheels off inspection yesterday to check brakes, rotors, suspension, and tires. Yes, using the lift I can inspect all of those items with the wheels on, but to get a really good look its easiest for me to remove the wheels so I have full access and clear visibility to everything.
As you can see, there is still pad (EBC Yellowstuff) remaining on the front brakes (rears have even more) but the rotors are starting to crack and there is some grooving on the face of the rotor (hard to photograph, easy to feel!).
The cracks are normal/expected. I got the light just right to highlight the biggest crack so it showed up in the photo. Because of this, I have to replace the rotors every time that I replace the pads. Solid or slotted rotors wouldn't crack but I tried them and think that the drilled rotors cool better and have a better feel as a result.
Tires (Toyo RR) are in good shape with generally even wear across the width of the tire. Looks like the alignment, especially camber, is set about right. There is still a reasonable amount of tread remaining after 8 heat cycles (three of which were races) since the wear dots (or whatever those little holes in the tread are called) are still visible.
