Old 02-03-2014, 06:42 PM   #179
Jamesp
Beginner
Jamesp's Avatar
Originally Posted by j.fro View Post
Tower integrity did not change from the cuts. The KSport hat is a pretty thick piece of aluminum, and all of the stress is distributed away from the cuts.
I'm not so sure. Round holes are much more structually efficient than square due to stress concentrations at the corners of square holes, not to mention the corresponding reduction in material. Bolt holes should have a minimum of 1.5 times bolt diameter to edge distance for similar reasons. Don't get me wrong, I'm all for owner inspired redesign, I've drilled holes in my intermediate shaft, but the modification should take into account engineering principles. So +1 on stepping out and making the mod. Just the same, the big square hole with the limited bolt hole to edge dimension is outside my comfort zone. I do give seningen props for making the mod. I hope it works well.
2003 S manual
