Old 01-26-2014, 09:20 PM   #3
Shehadehd
Shehadehd's Avatar
It could be a very serious problem as woodsman said. However, I had the equivalent code for bank 1 a while ago. I then switched the sensor with the one in bank 2 and got the exact error message you are getting. In my case, it was a sensor failure that caused the code and after replacing the sensor, (~$100) the code never came back.
I wouldn't really recommend swapping the sensors since bank 1 sensor is a real PITA to get too as it is under the AOS. You might also damage something for real in the process. You can always buy a new sensor and replace yours to see if it fixes anything. If you start getting any other CELS, though, flatbed it to the mechanic.
If you are interested in a Comfort-Top module, please visit:
https://www.enhancedautomods.com/shop/comfort-top
Shehadehd is offline   Reply With Quote
