Originally Posted by 993innc
The 993 was similar but I cooked tires without enough camber. I'm thinking this time about adjustable camber plates for the front to dial in 3 degrees (or as close as possible).
Camber plates will provide about one additional degree of camber over stock which means that you'll max out at a bit over -2 deg. This will probably not be enough to keep from cooking the tires.
