Thread: AFR Issue
Old 01-21-2014, 12:02 PM   #1
JAAY
JAAY's Avatar
The 987 airbox is a must. It does fit with the engine not lowered. I put mine in while the motor was in. It's a pain in the ass. Basically you have to cut off any extra plastic on the box and remove the intake manifold on that side. It was a lot of trial and error but it is the best intake for our car. If you decided to put a wide band 02 sensor and gauge in I can walk you through the setup and tuning. All the gear that I am using below.
Digital Wideband Air/Fuel Gauge
http://www.summitracing.com/parts/apx-401-a018?seid=srese1&gclid=CPvdh9KHkLwCFag7Ogod0zQA8g
Auto Meter® 20014 - Porsche Boxster 1997-2001 Single Steering Column Black Gauge Pod (For 2-1/16'' Gauges)
JAAY is offline   Reply With Quote
