Old 01-20-2014, 01:47 PM   #3
thstone
The spark plug tubes seal the access hole through the cam covers so you can reach the spark plugs. The two O-rings on the spark plug tubes can leak over time or the plastic tube itself can crack from age, both of these conditions may result in an oil leak coming from the spark plug area. If this is the case, then its an easy fix and any oil that may have dripped onto the exhaust manifold should burn off in a very short time.
However, be sure that the cam covers themselves are not leaking, dripping, or seeping. Resealing the cam covers is a someone complicated job and can run $1000 (I just had mine resealed on the 996). A drip from the cam cover will also typically end up on the exhaust manifold and result in a burning oil smell and even smoking.
Its not clear if the "dealer" you mention is a Porsche dealer or just a used car dealer. Either way, have a good independent PPI done so you know what's going on.
