			When the running lights are on but not the headlight switch my headlights emit a dim light.
Is that from a small seperate bulb or do the hight or low beams get lit with reduced voltage through a resister?
I was wondering if this is an issue for the projectors or if that is not the same circuit that the projectors use?
				"It broke because it wants to be Upgraded   "
Short Shifter, Touch Screen Dual Din Radio, 03 4 Bow glass Top  (DD & Auto-X since May 17,2012)
