Old 01-06-2014, 12:29 PM   #11
seningen
seningen's Avatar
This was merely an Omen telling you the metal flakes in your filter indicate you should pull & clean your sump pan. Buy a LN drainplug to prevent future plug problems. Make sure the pan & case mounting flange are sanitized with rubbing alcohol before applying sealant & reassembling. Haste makes waste!
You should expect to have to remove some old sealant -- so be sure to have something to scrub it off.
I used a 3M Tapered Bristle Disc,2 In Dia,80G - Abrasive Bristle Disc-Cup Shaped - 6RX77|18732 - Grainger Industrial Supply
on a air tool -- but a cordless drill would work as well.
I'm sure it or something similar can be found locally.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
