Haste makes Waste?
This was merely an Omen telling you the metal flakes in your filter indicate you should pull & clean your sump pan. Buy a LN drainplug to prevent future plug problems. Make sure the pan & case mounting flange are sanitized with rubbing alcohol before applying sealant & reassembling. Haste makes waste!
