Could be very expensive. 7.2 DME for 1999 to 2002 is different the cams are not controlled the same. the cam sensor is at cylinder 3 and 4 electro-mechanical adjustor adjusts the chains. 3 chain 2003 to 2006, 7.8 DME cam is control by valve and clutch on the intake cam sprocket. Cam sensors at cylinder 1 and 6
Engine
7.8 DME
Harnesses
immobilizer with key fabs
