Engine intolerance to overheating & broken pump impeller blades blocking cylinder head capillaries = potential severe lightening of wallet....
And if someone has fitted an aftermarket pump with metal impellers, a failed pump bearing can cause the impeller to grind through the alloy block which = even bigger expenditure....
2001 MV Agusta F4.
