Old 01-03-2014, 03:10 PM   #2
Jamesp
Beginner
Jamesp's Avatar
The most overlooked and important part to change out even though you're not told to, is the single row IMS bearing. The double rows do crater, but not as often. The single row IMS bearings are quite likely to be the part that defines the life of your engine. If you own a single row, do yourself a favor and have it replaced with an open ceramic at a minimum. I bought a 120K mile roller with, you guessed it, a failed IMSB. I've done quite a bit of research on the IMSB, and from what I have learned I'll be servicing mine just like old Honda timing belts were changed. If this bearing fails, you'll need a new engine.
2003 S manual
