Originally Posted by Brad Roberts
Tom? Did you figure this out?
This happened to my cars 2 times this past year at track events. One car had a dead battery (we pushed started it) and the ABS needs a lot of AMPS to work properly, then another car had a damaged ABS sensor wire under the dash that was "buzzed" by the fabricator during the cage install and missed by me during the build
I was not able to figure out why the ABS did not engage in this instance. ABS wiring and sensors seem to be working fine, checked in shop and work fine out on the track. On the good side, it has not repeated either. Ghost in the machine (for now).
