Old 12-28-2013, 08:48 PM   #2
KevinH1990
KevinH1990's Avatar
I used this DIY for installing my heated seats: Dennis Vogel: Projects - Boxster Heated Seats
It had a good description of the process for disassembling the lower part of the dash and removing the center console to run wiring under it. It also provides the part numbers and procedures for tapping into the center fuse box. If you use this to take apart the dash and console, you will see several options for running the wire.
There is a rubber grommet behind the center console that you can push a wire through. You may have to remove the sound-deadening material covering the rear bulkhead, but that is easy.
By the way, this is the part that you need to connect to the fuse box:
Repair Wire 000 979 227 [Wide 2.5mm] - 000979227 - IDParts.com
It comes with two connectors, and I only needed one. If you want the extra, send me a PM and I'll let you have it for $5 plus shipping. I see that you are in Europe, so I'm not sure if there are import restrictions that make this type of transaction difficult.
