You are reading way too much into this; the cam deviation values are the ones you should be reading as steady, the actual cam angles will move depending upon what the VarioCam is up to at that moment.
Cam angles should be just below the cam deviation values on the actual values list:
I don't have the actual angles to click on. Not sure why but went through the list 50 times. Has the inlet but not just the actual angel. Thanks JFP. I a, not concerned. Just trying to understand.
