Old 11-23-2013, 12:49 PM   #1
jsceash
jsceash's Avatar
What Is Your Hairiest Turn
Track season is over in the northest and unless your in the southwest yours is over as well.
What is your Most challenging turn(s)?
Mine is Turn 6 at Watkins Glen In reality it probably isn't that bad but the combination of thing that come into effect make it a turn you get or don't get. Starting at the Bus stop a four turn combination after in my case the 130 to 135 MPH back straight. Braking for about 150 - 200 yards to 75 to 80 MPH the four turn combination maintaining 75 - 80 MPH put you out onto the carrousel down hill turn 5 accelerating down hill 127' elevation to about 115 MPH. You finally get straight long enough to brake, downshift, and cut left into turn 6 off camber at about 60 MPH. As soon as the front end bites trail brake until the rear is in and set, get back to the gas gradually accelerating to the Apex still off chamber to full throttle at the apex still off chamber finally levels and the chamber cuts back to the turn as you accelerate out to the curbing drivers right at about 85- 90 MPH finally straightening Up shift to fourth to turn 7 the toe of the boot again to about 115 MPH braking downshift back to third at 70 MPH off the brakes fully into the throttle right turn uphil not realy accelerating for about the 75 ' climb out to the sole. I know I did it right if my back hurt being pulled down into the seat apex-in to apex-out and my data recorder shows about 1.3 to 1.5 G load.
