[QUOTE=Usedclassic;372011]Hi.
2002 Boxster 2.7 83000miles.
I have a problem with the passenger window in that it will not close fully when the car in in use. When locked it closes, but when you unlock the car it opens the 1/2 inch to allow the door to be opened and stays open. The interior light also stays on. The door lock rocker switch on the dash will not lock the car either.
I have disconnected the inner and outer door handle switches in turn, but doesn't help.
I think it must be the interior light switch - is that in the door latch ?
Or has anybody got any other ideas ??
Thanks, Steve
how is it that you can fully close the window before locking. or does the window go up when you lock the car?
{{played with the door and found that i can pull the door handle, window will come down, and as long as the door is held shut, the car will lock and the window goes up. based on this one data point, it would appear that the switch in the door mechanism that indicates door handle being pulled is stuck on the "door handle is pulled state" }}
Reason: additional info
