Originally Posted by SD987
The inability to push the shifter into first gear at inopportune moments, reported by myself and a couple of other over at ppbb.
Fortunately, this lock-out seems to be a rare flaw found in certain 5-speeds installed on 2005 987s (obviously, not the S model).
I have this problem in my 987S 6 speed where I cannot shift from neutral into first gear when rolling (in neutral) above 4 or 5 mph. This is a problem because sometimes selecting second gear isn't an appropriate starting gear when rolling between 5-10mph (especially up hill). Whenever this happens, I have to stop the car, shift to first, then drive on - often pissing off those who are following. If I select 2nd, I have to slip the clutch and bog the engine.
Any suggestions?
