Old 10-28-2013, 09:15 AM   #2
rick3000
There Is No Substitute.
rick3000's Avatar
A few people have removed the top. I am not sure about the exactly weight but it is at least 80 lb.'s (I am guessing with this number). If I recall it is only a few bolts to remove the top and top frame.
Try searching for 2003-2004 top retrofit for information on removing the entire frame. A few people upgraded pre-2003 tops, because the newer 986 tops allow the larger glass window upgrade due to having 4 top supports instead of the previous 3 supports.
