Originally Posted by Kirk
You can see in the picture that the 6305 bearing has thicker races. The width of the 6204 bearing is 14mm while the 6305 is 17mm wide (or what I believe you are calling thick). So yes, the 6305 bearing is bigger all around. It also has bigger balls...
Kirk Bristol
Ok, lets remember this statement leading into the future when discussing the the problem with the M96 IMSB is only limited to lubrication.
If the problem was limited to lubrication, then Kirk's observation and most recent statements would not be relevant, but they are.
US Patent 8,992,089 &
US Patent 9,416,697
