Old 10-25-2013, 10:02 AM   #111
Kirk
Originally Posted by cnavarro View Post
Where are you getting your data from on load capacities?
I am getting my load data for the steel bearing from SKF as I plan to use this brand in my personal car. The load data for your bearing came from your website:
"The 6204 bearing currently used in the LN Engineering IMS Retrofit has a dynamic load capacity of 2900#"
If that is not correct, then I would invite you to post static and dynamic load ratings for your IMS Retrofit bearing. But based on this information the SKF 6204 with a dynamic load rating of 3,032# certainly appears to be comparable to the IMS Retrofit, if not marginally better. More details are in the Pelican Parts thread.
Kirk Bristol
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
