I have some experience on this as I did this between January through March this year. The pipe off the 3.2 motor fit the hoses from the 2.7 motor I replace both of those hose with the same parts and clamps. I bought the OEM tee hoses, center radiator and frame from the dealer. The tee hose is larger by about 1/8". When I removed the original hose from the left and right side radiator I slipped on 2 new spring clamps on the end that clamps the original plumbing. I was able to loosen and slide the hose and connector from under the chasis enough to get 2 clamps on the new slightly larger Tee hose. The connector pipe has 2 ribs One clamp before the first rib one clamp between the ribs. No drip no dribble in 6200 miles and 15 track days.
