You have to be careful about the wheels and the offset. Those look like three piece 911 wheel and if they rub the inside of the fenders there is pretty much nothing you can do short of raising the car. Spacers will only make the rub worse. 245 35 19 are too large around you should be looking for tires with an outside diameter of about 25.00 to 25.375" the 245 35 19 tire run about 25.75"
