I am very happy with the Pagid RS-14 Black compound front and rear. They heat up quickly, and never fade in my experience.
I am using the ATE SuperBlue like you, and completley change the fluid for every DE, unless I have two events within a 2- 3 month period, then I'll just run the same fluid for those events.
I am using the GT2 brake "ducts" (really more of an air turning vane), which as I understand are a bit larger than the GT3 units.
You may want to check the discs regularly for cracks. They all crack after a couple of events, but throw away when cracks start going hole to hole.
Kippis
986S
991S
Van Diemen RF97
