Old 10-11-2013, 02:25 PM   #1
Jittsl
SPB racer
Originally Posted by bam914 View Post
You can do it with a two pole switch. I have the main power distribution, which is under the dash, lead on one side of the switch and the battery on the other. Kills the power to everything.
No it doesn't. As long as the motor is still spinning the alternator is still producing power and the motor will run indefinately. You need a six pole so that you can ground out the alternator as well as kill the power supply to the motor (there is a relay in the rear that you can switch the power to and kill all motor function as well as the output of the battery. Two pole will not kill a modern car.
For those with two pole switches try the following- rev engine to 2500rpm and pull kill switch. Does your engine stop?
Jittsl is offline   Reply With Quote
