Originally Posted by evan9eleven
Thanks for the info, I didn't know that about the stagger, so I have learned something useful there.
OEM on the 18" Carrera wheels are 225/40 and 265/35. So 40mm of stagger. Following your advice then, if I go with 275's in the rear I should also upsize the fronts to 235's. Or downsize to 255s in the rear, though I don't know if my desired tires are available in that size over here or in the correct aspect ratio.
Yes, this can result in a lot of searching for specific tire sizes that may or may not exist. At the end of the day, most of us just do the best we can in balancing all of these tradeoffs.
