Old 10-07-2013, 08:22 AM   #4
Hayden
Hayden's Avatar
I'd start with the intake side of things, and check the MAF. It seems a more likely culprit than the exhaust tuning, which as I understand your setup to be, shouldn't cause a massive dead spot. There's a lot of flow dynamics in the intake path so that air hits the MAF in a way that is in accordance with the rest of the system. Turbulence/swirling could be a factor.
Hayden is offline   Reply With Quote
