Thread: fuel treatment
Old 10-05-2013, 10:40 AM   #3
jsceash
jsceash's Avatar
I believe your OK the item mention in the previous post are more scare tactic than fact. Head gaskets are 3 ply stainless steel. If you get this in to your rod and bearing your using it wrong, or you have more serious problems like ring blow by. They are designed to clean injectors and valves stem and any carbon build up. Like the previous post you will probably get lost power back unless they are designed to improve the effect of ethanol in your fuel. Almost all engines today have a high percentage of aluminum in head and cylinders. The manufactures of these product could ill afford the consequence of supplying a product that damaged aluminum while burning.
