1) Parasitic drain is in mA not v - it is a continuous drain on the battery & over several days will flatten the battery.But by what you said it may be OK, but it costs nothing to check...
2) You need a specialised tester to determine if the alternator vs regulator is at fault - I can't help you with this.
3) Load testing the battery is a good idea - even if its only 30 months old and maybe still under warranty.
2001 MV Agusta F4.
