Old 09-30-2013, 11:18 AM   #10
jb92563
jb92563's Avatar
Thom that is an important distinction which means that the Bearing upgrade AND DOF should be done together for those single row bearings as just the DOF alone in that case would not solve the issue.
Is there any data to confirm the actual cause of failure or are there multiple root causes in various cases?
Its hard to imagine that the Engineers decided to use a bearing that is not structurally sufficient for the loads encountered.
I'd sooner believe that the bearings fail for other root causes such as the acidic pitting, lack of proper lubrication, over heating etc, but I suppose human design error is also a possibility
