Losing coolant could be from a cracked coolant tank or pipe. A wet trunk under the liner is a syptom of that.
A dying water pump is also a possibility if the is a puddle under the engine.
Puddle under the front of the car means leaky connectors at the radiators or the rad itself.
If the oil on the dipstick is like a milkshake then water is getting into the engine through a cracked cylinder or head.
You need to determine where your losing it ASAP else bad and expensive things could happen.
"It broke because it wants to be Upgraded  "
