Thanks for your help Jake.
Just want to point out the magnetic plug pics are macro so the camera lens is only about 2-3 inches away from the plug.
Also the bearing that turned, was on the main crank shaft, it was the end bearing in the bearing case just before the crank pulley (opposite end to flywheel). I hope this is a clear enough discription.
