removed the sump this morning.
First impression was it looked clean. There are a few small bits of sealant goop but appeared to be nothing else.
Just to make sure, I took the magnetic drain plug and dragged it over the entire surface of the pan and the macro pic of the drain plug is the result.
Considering this is the 1st stage oil change in a rebuilt I would have thought there should be some bits?
When I looked up into the engine cavity it look clean. Pick up strainer had a small piece of sealant goop but that was it.
