Fronts are fine. You can run 42mm - 47mm on a Box on the rear. I'd go with 45mm; any more and your tires will hit the e-brake cables and you'll have to tie them out of the way. You'll need 7mm spacers for this. you'll also need longer bolts (73mm).
if you choose to go for 5mm spacers (47mm offset), you can use the stock bolts. this will save you about $120. i got my spacers and bolts from ********************************.com. if you get new bolts, you will have to remove the cones from your old bolts and put them on the new ones (a pain).
