Old 09-08-2013, 09:03 AM   #10
smygolf
Just a Swede
@thom4782
That was what i was thinking of doing, but doesn't the Cable only effect the "B pillar"
I just had a Little brainstorm and id did a check off the alignment of the seals.
And the B pillar seal has moved!
So with a gentle touched i removed it, gave it a good Clean. When it was loose one could see that there is a bit o play.
So Before i remounted the seal i gave it a Little bit of oil.
No it sits Perfectly, but where is the rain?!
I also have a bunch of towels where the water traveled Before so with a Little bit of luck!!!!
Btw, Thanks Guys!
*edit*
i didn't loose the screws in the bottom.
smygolf is offline   Reply With Quote
